Landrovernuts Posted September 28, 2015 Share Posted September 28, 2015 If I was to change the front axle on a TD5 110 to an earlier axle casing (1989 thicker drive flanges), is there any issue with Panhard Rod sizes (bush/bolt sizes)? This may seem a backward step - but believe me it is not in this case! I think everything else changes over with no issues, but feel free to correct me if wrong. I would rather know now, than as I am swapping them. I know alloys will not fit over the earlier drive flanges, but is not an issue here. Toby Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 28, 2015 Share Posted September 28, 2015 ABS? Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 28, 2015 Share Posted September 28, 2015 An 89 axle might still have the narrow style of radius arms you'd have to check it. Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted September 28, 2015 Author Share Posted September 28, 2015 No ABS, but had forgotten about radius arms - will check now! Thanks Toby Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted September 28, 2015 Author Share Posted September 28, 2015 Yup, need some narrow radius arms - think I know where there is some! Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted September 28, 2015 Author Share Posted September 28, 2015 Anyone know if there is an issue with the Panhard Rod not fitting? Toby Quote Link to comment Share on other sites More sharing options...
western Posted September 28, 2015 Share Posted September 28, 2015 same part on all pre Tdci 90/110 as far as I know. the old 7 digit part number changes to RBI100000 info from http://www.lrseries.com/shop/product/listing/10228/RBI100000-PANHARD-ROD.html?search=nrc9729&page=1 Product Description:Front suspension panhard rod complete with bushes.S/S NRC9729 Part number:RBI100000 Applicable Models:Wolf XD modelsDefender VA****** onwards Earlier vehicle are M16 bolt holes.Discovery 1 also item 14 in http://lrcat.com/#31/4/52609 shows RBI100031 & RBI100041 but no more info. bolt lengths changes from M16 x 82mm to M14 x 80mm see items 16 & 17 in link above, all are metric Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted September 28, 2015 Share Posted September 28, 2015 I did the opposite...I have an 02 td5 front on my 90, no issues with the HD panhard rod which I had fitted to the '86 axle Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted September 29, 2015 Share Posted September 29, 2015 I fairly recently did some swapping round of bits from a 1996 Discovery to a 1985 90, the panhard rod, bushes and bolts all interchanged. Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted September 29, 2015 Author Share Posted September 29, 2015 Thanks all - just need to get the thin radius arms and then get on with it! Toby Quote Link to comment Share on other sites More sharing options...
Litch Posted September 29, 2015 Share Posted September 29, 2015 You shouldn't have any issues there, most people are swopping the other way and some can hardly give the thin ones away. Quote Link to comment Share on other sites More sharing options...
