Theviper1987 Posted October 19, 2015 Share Posted October 19, 2015 Hi all I no it not the right thing etc etc etc. But how do I go about getting the overrun 'burble/popping'(that is a word I have just made up). When u floor it then back off. Do I just add fuel right across the map kpa 15 line? Thanks 1 Quote Link to comment Share on other sites More sharing options...
Quagmire Posted October 19, 2015 Share Posted October 19, 2015 Instead of doing the usual and leaning out in the low load areas of the map, just up the ve values to add a load in. At least I thinks its that easy... Maybe regard timimg too? A guru from here can confirm/deny my suspicions... Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted October 19, 2015 Author Share Posted October 19, 2015 Thanks I'll be having a play tomorrow I think. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 19, 2015 Share Posted October 19, 2015 Yes, was going to say, makes sense to me to up the fuelling, turn off the fuel cut on overrun of course, and then retard timing, quite a lot... Not tried it, but the theory says flames out the exhaust Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted October 19, 2015 Author Share Posted October 19, 2015 Sounds like fun!! I have a pair of 3" stacks aswell!! Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted October 19, 2015 Author Share Posted October 19, 2015 How would I go about turning the fuel cut off on over run?? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 19, 2015 Share Posted October 19, 2015 It's in one the basic settings on megatune/tunerstudio, you need it OFF. Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted October 20, 2015 Author Share Posted October 20, 2015 Ok thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 20, 2015 Share Posted October 20, 2015 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 20, 2015 Share Posted October 20, 2015 Thank you, have to install Java again after updating to OSX El Capitan the other day, and TS wouldn't run Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted October 20, 2015 Author Share Posted October 20, 2015 Right ow thanks all I'll let u no how I get on! Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted October 20, 2015 Author Share Posted October 20, 2015 Also while I have all of urs attention. My ts keeps on going off line on auto tune. Then re starting. Is this a common fault or is there an update I'm missing Quote Link to comment Share on other sites More sharing options...
Rangie46 Posted October 21, 2015 Share Posted October 21, 2015 Also while I have all of urs attention. My ts keeps on going off line on auto tune. Then re starting. Is this a common fault or is there an update I'm missing Mine does the same but I think it is the usb to serial connection, the usb plug is a bit loose so I tape it down to the laptop Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 21, 2015 Share Posted October 21, 2015 If the time counter restarts it's the ECU resetting (Megatune detects this I think, I assume TS would too), if it keeps on rolling then it's most likely a loose cable. I don't think this value is displayed as default but it gets logged. Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted October 21, 2015 Author Share Posted October 21, 2015 Ok. It done any bother me as the autotune table doesn't reset. I was just wounding y It did it. Also I'm using a USB adapter thing aswell Quote Link to comment Share on other sites More sharing options...
rangie92 Posted November 16, 2015 Share Posted November 16, 2015 Tuner studio auto tune stopping or saying ecu is offline even though the engine is running and ecu still plugged into the laptop can be as simple as the usb cable is sitting directly on top or crossing power cables wether they are the vehicle power or the power supply for laptop as I discovered yesterday after experiencing these problems Quote Link to comment Share on other sites More sharing options...
