MuddyWinny Posted October 22, 2015 Share Posted October 22, 2015 I tend to use one of these, simple pipe plugged at one end with a slit: http://www.vehicle-wiring-products.eu/product.php/115/brake-bleed-tube Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 22, 2015 Share Posted October 22, 2015 Blank the end of the tube with a bolt or something similar, then make a slit in it near the end with a razor blade, stanley knife, etc. The slit will act as a valve and no air will be drawn back. Les Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted October 23, 2015 Author Share Posted October 23, 2015 I tend to use one of these, simple pipe plugged at one end with a slit: http://www.vehicle-wiring-products.eu/product.php/115/brake-bleed-tube Blank the end of the tube with a bolt or something similar, then make a slit in it near the end with a razor blade, stanley knife, etc. The slit will act as a valve and no air will be drawn back. Les So simple it has to work! I'm going to make one of these, and then if that fails order a master cylinder. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 24, 2015 Share Posted October 24, 2015 It does work and very well too ? Mo Quote Link to comment Share on other sites More sharing options...
