Disco 2 axles on defender.
skauldy
Hi Guys,
Does anyone know of any threads of someone fitting disco 2 axles to a defenders. Have seen plenty of threads about talking about it but none of someone actually wanting to do it. I have read what involved but would like to see pics. Thanks
Shane
Stronger internals, better steering lock, a little wider, better brakes and the hubs are nicer to work on
Tomcat Motorsport have a jig to weld brackets on to axles. I would go to them as it will be done to a professional standard and the castor angles will be correct
It's not that hard of a job to be honest. It's simpler than some people make out! I would go along the lines of using the disco radius arms and if possible fitting the watts linkage too, if not stick an a-frame ball joint mount on the rd5 axle. I've done a couple now, most recently on a tomcat for ultra4, however we are putting a 4-link setup on the rear rather than conventional setup
Thanks for all the replies guys.
I just want to see what way the brackets were welded etc. On. I'm very good at copying how other people done stuff but not very good at pioneering new ways.
Is it better to keep the defender radius arms or weld the disco boxes onto my chassis so I get the traverse bolt setup. If am going the disco route using the arms how do I do the back.
Thanks Wanger. Will have a flick through the link
I would go down the route of disco arms personally. What do you mean how do you do the back? Any part in particular you are unsure of?
Just make sure your arms do not clash with the front outrigger on full bump it might need scolloping to cope but don't remove the outrigger as its the only substantial thing between your feet and the front wheel in the event of a crash!
i am strongly concidering this xle conversion for some time. i have spoken to loads of people on this and have come to final conclusion that using d2 front arms all round (cutting second eye off front so they fit on rear) would require some easy to make brackets to weld on chassis, the front defender radius arm mounts need to be removed and on a 90, a smaller bracket is needed as tank in in the way. with the d2 arms all round makes good ride and allows best downwards acticulation (as arms are longer and better bushes at chassis ends), loads more than standard 90/110 arms and then some. but dont allow axles to twist over ruts etc which almost defeats the whole point. diffs are same lenght as 90/110 so props wont need changing. i have now come to decide that for me, cut off all mounts and weld d1/90/110 mounts from YRM so d2 axles will fit will all defender suspention with aframe. that will allow me to keep my chassis standard (ideal if you have a galv chassis) but i would use d2 axles with either double cranked or jonny joined arms for max down artiulation and cross axle ability. if you go d2 arms, then i beleive mikeys friend is develping a kit to make installation much easier.
Johnny jointed arms on a chassis with standard mounts is a waste of time. You shorten the arm and end up with hideous axle walk when articulating.
what would be best option to use at the chasis end? i did think about rose jointed but they allow alot of driveline vibration to transmit through the rest of the vehicle and sway and 'chatter' when worn. poly bus hand souble cranked best way forwrards? :)
Well anything that makes the trailing arm shorter means more axle walk. So using johnny joints or rose joints you need to move the mounts forward. Best bet if you're staying with a standard chassis mount has to be the XArms. They retain the same length arm and are much freer moving than a normal LR bush. If you stay with the normal LR bush, your best bet is genuine rubber bush or Super Pro.
I have used the Disco 2 axles front and rear
I also got the brackets from YRM
cutting off the old ones and welding YRM brackets on
Have a look at my build pages to give you a bit of an idea
http://forums.lr4x4.com/index.php?showtopic=81668
Feel a bit more confident to do the conversion. Think I will just swap the mounts on the axles rather then the chassis. Bank holiday here so will ring around tomorrow for prices on the d2 axles. Thanks for all the replies guys.
That seems like rather a lot of work when all said and done. And I'm still not sure what the real world gains would be. What would you be able to do, that you couldn't on Defender axles?
They might be cheaper to upgrade, but is the cost difference really that big? Not too mention it's not exactly a free conversion in time or money. So I'd be amazed if you could really swap them on and make it cheaper. More likely more expensive overall.
As for the steering and wider. Ok they might be benefits, but what difference are we talking? And if all you are doing is running 32-35" tyres, then are you really going to see these advantages from the drivers seat?
I'm by no means saying don't do it. Just trying to understand what real advantages there are, vs the cost and effort of the swap.
a large benefit is the size of the CV that you can fit in the knuckle on a TD5 axle compared to the size of CV you can get in a standard defender axle.
Another benefit being the wheelbearing type much less prone to failure, although they are more expensive to change. and the brakes are much simpler to service
??? They have weaker internals and worse brakes.
The diffs are the same as any previous coiler. I'd agree that they're worse brakes too... I hate sliding calipers with a passion! I was chatting to David at Llama4x4 when I bought my rear brake lines and I was talking about plans for the car and about not using stainless flexi throughout. He had a story of a Disco 2 based racer which couldn't get a decent pedal. It turned out that it was the calliper flexing!
