Hybrid_From_Hell Posted September 12, 2005 Share Posted September 12, 2005 2nd attempt, On the 90 at the I have the original "hopeless" fuel cap that just sort of screws on..... When I am at a angle it sort of dribbles, (bit like it owner at times them) and fuel comes out, This means water and plop can also get in, not clever. I used to have on the Hybrid one of those demon tweeks whizzy aircrfat caps, loads of polish ali and allen bolts, but it was a sealed cap no breather. Has anyone converted there rather poor LR cap to one of these, which one did you use, what hose to connect did it fit ok, or how / what needs to be done and what about a breather in the tank, how did you soprt that out ?? Hope the above post makes sense, just got in from 5 hours drive back from Exeter (a303 closed ) and am knackered, just about to have a meeting with Mr Guinness and his 5 friends Nige Quote Link to comment Share on other sites More sharing options...
MogLite Posted September 12, 2005 Share Posted September 12, 2005 If I was being a skint flint...... I'd look at making a motorbike cap fit - nice ones off of modern sports bikes shouldn't be too hard to come by. Just get a hose to fit on the reverse might cause a bit of head scratching. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 13, 2005 Share Posted September 13, 2005 Has anyone converted there rather poor LR cap to one of these, which one did you use, what hose to connect did it fit ok, or how / what needs to be done and what about a breather in the tank, how did you soprt that out ?? re: breather; a one way vavle for an aquarium air line plus some air line; cost about £3 all in. Not sure how you would attach it; proably have to drill a hole in the tank and fit a hose connector, ideally a screw on type as opposed to solder type. hmmm but not sure how it would cope with diesel/petrol.... Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted September 13, 2005 Share Posted September 13, 2005 P A R I S hose and ducting will get you any hose available, we use them for work, 01344 758600 Geoff is the man. Quote Link to comment Share on other sites More sharing options...
