mattytd4offroad Posted November 12, 2015 Share Posted November 12, 2015 hi all new to this group just after some help and tips if anyone has any on changing the engine on my td4, Im only changing the engine if i have, as oil got blown out of the dip stick as i think the crank breather was blocked but no sure, also as result i think the turbo seals have gone as when i changed the crank case beather i removed inlet manifold, egr, and intercooler pipes and cleaned them up drove around the block and oil in the intercooler pipes again. but if i disconnect the intercooler pipe and start the car from cold i get little blue smoke then clears and will be fine on idle but when i rev at 2000 rpm and hold it there blue smoke starts coming out the back all this with the intercooler pipe off it the same with it on, but just saying its the same on or off. if anyone has any ideas what this may be would be a help, i have brought another engine but if i can fix this one i wont have to change it, but worst case if i do can i lift the engine out through the bonnet or does it have to come out from underneath? matt Quote Link to comment Share on other sites More sharing options...
Skogsmulle Posted September 2, 2016 Share Posted September 2, 2016 hi all new to this group just after some help and tips if anyone has any on changing the engine on my td4, Im only changing the engine if i have, as oil got blown out of the dip stick as i think the crank breather was blocked but no sure, also as result i think the turbo seals have gone as when i changed the crank case beather i removed inlet manifold, egr, and intercooler pipes and cleaned them up drove around the block and oil in the intercooler pipes again. but if i disconnect the intercooler pipe and start the car from cold i get little blue smoke then clears and will be fine on idle but when i rev at 2000 rpm and hold it there blue smoke starts coming out the back all this with the intercooler pipe off it the same with it on, but just saying its the same on or off. if anyone has any ideas what this may be would be a help, i have brought another engine but if i can fix this one i wont have to change it, but worst case if i do can i lift the engine out through the bonnet or does it have to come out from underneath? matt Hello How did you do? Must also change the engine due camshaft problems Quote Link to comment Share on other sites More sharing options...
