disco Engine into 90
Hello. I'm sure LOTS of people have made this mod and I did many years ago which is why I'm a little annoyed that I can't remember the answer. .
I've put a disco 200tdi into my new 90 and apart from the air box and coolant pipes etc etc I've found the oil cooler pipes are to short and for the life of me I can't remember how I resolve to problem last time. Can anyone help
many thanks.
Not sure whether it's the same diameter on a 200 but when I extended the 300tdi oil cooler lines, I just cut the pipes and used some central heating pipe with a couple of jubilee clips on each end as a temp fix.
It worked fine for a year until the local hydraulic place made up some new ones. IIRC new pipes and crimping the old unions to them was a total of £20 so a good saving over the Steve Parker set.
