casperboat Posted November 22, 2015 Share Posted November 22, 2015 Just connected up the battery and the lead sparked a little, i've seen it before when connecting up various things, but on the landy the 2 positive cables go straight to an isolator switch each, which was turned off, 1 in the cab, the other in the engine bay which used to be for a winch.. . Not sure how there could be a connection anywhere to make it spark.. It only sparks as the cable touches, once it's touched it's fine.. Regards. Quote Link to comment Share on other sites More sharing options...
Serious Series Posted November 22, 2015 Share Posted November 22, 2015 One of your supplies to the isolators has an earth fault on it or some times they have a fused supply linked across the isolator to feed small items like clock or radio. If you leave the connection on it .will eventually drain your battery 1 Quote Link to comment Share on other sites More sharing options...
casperboat Posted November 24, 2015 Author Share Posted November 24, 2015 Radio was correct, finally realised I had wired the stereo's memory to the permanently live side of the isolator... Quote Link to comment Share on other sites More sharing options...
