Disco-Ron Posted November 22, 2015 Share Posted November 22, 2015 As above, toying with doing it but unsure.... would rather not spend£200 to then spend another 600getting a rebuilt one..... Ta Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted November 22, 2015 Share Posted November 22, 2015 I've built one out of 2 bad ones in the past to get the brother in law out of the quagmire and it's easy enough with a bit of patience. The info from the WSM is freely available so I would suggest a few thorough reads through that, then make your mind up. Quote Link to comment Share on other sites More sharing options...
Boydie Posted November 23, 2015 Share Posted November 23, 2015 I've just done mine fitting an Ashcroft ATB differential. Read my thread on my removal, overhaul and re-install to give you some idea of what you will be up for, if you have a half decent workshop/shed, a hydraulic press and a set of hydraulic pullers you can manage it quite easily. Choose your bearings wisely, I went for Timken all through with genuine LR oil seals, spacers etc. Hardest part was getting it back onto the R380 without messing up the input oil seal. Use the long studs! Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted November 23, 2015 Author Share Posted November 23, 2015 I have swapped it before so not worried about that element. ... I don't have pullers...... and the shimming is my biggest concern. ... just don't want to get it wrong. .... have read the manual though and just can't decide. ..... Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 23, 2015 Share Posted November 23, 2015 Gearbox work is not hard if you just follow what's in the WSM Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted November 23, 2015 Author Share Posted November 23, 2015 I used to do mini gearboxes with my eyes closed. ... so I guess I should be able to do it ... Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 23, 2015 Share Posted November 23, 2015 You'll be fine! Quote Link to comment Share on other sites More sharing options...
tuko Posted November 23, 2015 Share Posted November 23, 2015 I recently installed the 1.003 ratio kit from Dave, if you do as everyone else has mentioned about the WSM, you'll do fine. ;-) Todd. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 23, 2015 Share Posted November 23, 2015 Yes, I rebuilt mine, fitted the HD cross pin in the diff along with new gears and thrust washers as well as a cross drilled input shaft. Relatively straight forward although I did read the manual a few times. Also handy to have access to a dial type torque wrench for the crush bearing as a standard click ones won't do. I bought the master rebuild kit iirc, it's done a good few thousand miles with no issues Quote Link to comment Share on other sites More sharing options...
