ejparrott Posted November 25, 2015 Share Posted November 25, 2015 I might have a look at that too, but I'm poised to order my TIG set for home from R-Tech any day anyway Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 25, 2015 Share Posted November 25, 2015 Always worth shopping around, my optrel should have been £480 when I bought it but ended up paying £268 Quote Link to comment Share on other sites More sharing options...
Ozzy50 Posted November 25, 2015 Share Posted November 25, 2015 They ain't cheap are they! Currently outside my budget, but I'm thinking I might buy an R-Tech helmet. As Nige said - I think - no-one's going to put their name on and risk a court case. I've looked at a lot of R-Tech stuff, they seem good, and I've heard a lot of people who've had first had experience say they're good, so I might give it a go.....and probably find there's nothing wrong with mine in the process.... I would recommend R Tech ,I have a plasma cutter and an arc welder from them and both are fantastic machines ,customer service is exellent, consumables no problem ,haven't tried one of their welding masks but I would be very surprised if it was anything but good . 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 25, 2015 Share Posted November 25, 2015 I paid 60 quid for mine, and I can't fault it. But then, like most on here, I do it for a hobby, not as a 6-days-a-week job (which is where it seems a lot of the replies for Speedglas have come from). Think what your use would be. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 25, 2015 Share Posted November 25, 2015 Speedglas for me, bought 10yrs ago still going strong. Quote Link to comment Share on other sites More sharing options...
robertspark Posted November 29, 2015 Share Posted November 29, 2015 Optrel satellite... About 13 years now with 3m positive pressure respirator (not used and removed) When you start to look at the autodimming function, you start to notice some of the better branded ones actually use the same Swiss made The trick is start checking the replacement glass and plastic lenses and you'll see them replicated between manufacturers.... Suspect the esab mask uses the older optrel autodimming device (when I last looked at one about a year ago) Rob Quote Link to comment Share on other sites More sharing options...
andy2986 Posted December 1, 2015 Author Share Posted December 1, 2015 I paid 60 quid for mine, and I can't fault it. But then, like most on here, I do it for a hobby, not as a 6-days-a-week job (which is where it seems a lot of the replies for Speedglas have come from). Think what your use would be. What helmet are you using ? Quote Link to comment Share on other sites More sharing options...
Tibout Posted December 6, 2015 Share Posted December 6, 2015 I work as a coded welded for Irish rail some very heavy welding both MIG, STICK and some TIG on pipe and we have the speeglas 9100xx adflo and it will last you more than a decade if you look after it. You don't need the adflo if you're not welding everyday just the helmet. The view is great and it's brilliant for any process you can see what you're doing. very expensive though. But worth it if you use it everyday. Quote Link to comment Share on other sites More sharing options...
peloquin Posted February 14, 2016 Share Posted February 14, 2016 I use a Tecmen Eagle at work. Around 160 quid all in, massive viewing area and very comfy. The graphics on it are a bit cheesy but you can't see them when you are inside it. Quote Link to comment Share on other sites More sharing options...
