Troll Hunter Posted November 23, 2015 Share Posted November 23, 2015 Please, some more help needed, but this time only in understanding the LR Manual. I'm looking at the torque values in the Defender 1996 300Tdi Workshop Manual and I can manage the Nm values, but what about the values expressed in degrees, eg the cylinder head bolts, which are variously shown as 60o + 60o or 60o + 60o + 20o, and my current concern, the rocker shaft to pedestal bolts, which are shown as 5o + 50o? What do the two or three degree values mean, please? Please can somebody bring me into the 21st century? Mike Quote Link to comment Share on other sites More sharing options...
rich broom Posted November 23, 2015 Share Posted November 23, 2015 It Is the degrees of a circle. So once tightened to the nm in sequence. Start again but turn 60degrees of a full turn. Do them all in sequence and then again. You will need a dial indicator tool. My torque wrench has degrees built into it Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted November 23, 2015 Author Share Posted November 23, 2015 I'm familiar with that type of torque specification, but in this case no initial torque value is given, so when should I start measuring degrees, and what does the 5o + 50o mean? Normally a torque value is given, followed by a single degree value of additional tightening to arrive at the final tension, not two degree values. So, back to the original question! Mike Quote Link to comment Share on other sites More sharing options...
rich broom Posted November 23, 2015 Share Posted November 23, 2015 I would recheck initial setting.Might be a typo. As you say. You need to start somewhere I would suspect 5nm Quote Link to comment Share on other sites More sharing options...
western Posted November 23, 2015 Share Posted November 23, 2015 for a 300tdi engine torqueing of cylinder head bolts, the book say tighten bolts so the flange on bolts is touching the cylinder head, then use torque to 40nm, then using the degree dial gauge on your torque wrench to tighten the stated number of degrees -- highlighted with the green lines on page below. you need one of these as well -------- http://www.ebay.co.uk/itm/like/140703714057?adgroupid=13936810266&hlpht=true&hlpv=2&rlsatarget=kwd-124296811266&adtype=pla&ff3=1&lpid=122&poi=1006597&ul_noapp=true&limghlpsr=true&ff19=0&device=c&chn=ps&campaignid=220881786&crdt=0&ff12=67&ff11=ICEP3.0.0-L&ff14=122&viphx=1&ops=true&ff13=80 1.so bolts in touching the cylinder head then in the sequence shown in small diagram above paragraph 30 2, torque to 40nm 3.tighten all bolts to 60 degrees 4. carry out number 3 again 5. tighten the 10 longer M12 bolts a further 20 degrees Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted November 23, 2015 Author Share Posted November 23, 2015 Rich, you're dead right. It is a misprint, and it should be 5Nm + 50o . Western, thanks for referring me to the text in the manual, where it does show the correct values. I had only been looking at the table of torque values, since in my other LR WSM no torque values are given in the text sections. So, on with the job! Mike Quote Link to comment Share on other sites More sharing options...
western Posted November 24, 2015 Share Posted November 24, 2015 glad it helped, hope the task goes well. Quote Link to comment Share on other sites More sharing options...
