sweeney110 Posted November 23, 2015 Share Posted November 23, 2015 Does anyone know where it's possible to buy the resistor and harness for the heater matrix? I know the one I have is shot. The rest of the system seems fine so I don't want to buy the whole unit if I don't have to. Thanks in advance Connor Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 24, 2015 Share Posted November 24, 2015 You might be better off buying the fan speed improvement kit which I think deletes the OEM resistor. I've got one here, but it's to work with a defender heater in a Series 3, so the wiring's completely different and the colours don't match up to the instructions! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 24, 2015 Share Posted November 24, 2015 Have a look here, item 4. Three options depending on which heater you have. http://www.allbrit.de/UNI.cfm?PAGE=760932&SPRACHE=EN None of them cheap!! http://www.johncraddockltd.co.uk/land-rover-parts/utp1904-wiring-assy-he.html http://www.johncraddockltd.co.uk/land-rover-defender/defender-90-and-110/parts/cooling-and-heating/utp1281-wiring-harness-and-resistor-for-heater-90110-r-h-d.html http://www.johncraddockltd.co.uk/land-rover-parts/jgk100170-wiring-assy-he.html Quote Link to comment Share on other sites More sharing options...
pete3000 Posted November 24, 2015 Share Posted November 24, 2015 Adapt something like this? http://www.island-4x4.co.uk/heater-resistor-britpart-da4178resistor-p-7373.html or http://www.ebay.co.uk/itm/2X-100W-Metal-Aluminum-Case-Wire-wound-Power-Resistor-1R-2R-4R-8R-10R-Ohm-/400899083687?var=&hash=item5d57728da7:m:mUqgUd381ie1z6LscL-IVeQ should only need a 1 or 2 ohm power resistor in series with the fan. (must be in the airflow before the matrix to cool the resistor) Quote Link to comment Share on other sites More sharing options...
western Posted November 24, 2015 Share Posted November 24, 2015 get hold of simonb on here, he should be able to sort one of his heater fan kits for you, got one on my 110's heater it works very well. Quote Link to comment Share on other sites More sharing options...
sweeney110 Posted November 24, 2015 Author Share Posted November 24, 2015 Thanks all. I'll try to get it sorted for the weekend. -3℃ with us the night before last. High time it was working again. Quote Link to comment Share on other sites More sharing options...
simonb Posted November 25, 2015 Share Posted November 25, 2015 get hold of simonb on here, he should be able to sort one of his heater fan kits for you, got one on my 110's heater it works very well. PM me if you want one, forum discount applies. I'll be listing them on eblag again at the wknd. 1 Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted November 25, 2015 Share Posted November 25, 2015 Can you give some more details on your kit please Simon. My heater fan is also rather pants, even on flat out. Quote Link to comment Share on other sites More sharing options...
simonb Posted November 26, 2015 Share Posted November 26, 2015 PM me for details, but if its rubbish on fast speed, then it sounds like your motor needs and overhaul. The bearings dry out. I think (its a while since I've had one apart) but the brushes are the same as the wiper motor. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 26, 2015 Share Posted November 26, 2015 Motor takes 12v direct on full speed, so it should be pretty bloody good - better than a series one on full chat! Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted November 26, 2015 Share Posted November 26, 2015 Mine only works on the slower speed. ... what's potentially the issue? ?..... Quote Link to comment Share on other sites More sharing options...
pete3000 Posted November 26, 2015 Share Posted November 26, 2015 the switch? one of the spades fell off? if it's working on slow speed the motor and supply are ok, as well as the resistor. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted November 26, 2015 Share Posted November 26, 2015 Both connectors are intact. ... so probably the switch itself I guess. ... ta Quote Link to comment Share on other sites More sharing options...
L19MUD Posted November 27, 2015 Share Posted November 27, 2015 Mine is not working at all. Admittedly have not checked anything yet It is likely to be the resistor? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 27, 2015 Share Posted November 27, 2015 Not if it doesn't work on full speed, the resistor will be bypassed. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted November 28, 2015 Share Posted November 28, 2015 the newer 3 way fan connector type, (econoseal)? from vwp) can rot out. inspect the plug socket next tothe fan under the bonnet. pull both halves and check the pins for corrosion, or even if they are still there. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 28, 2015 Share Posted November 28, 2015 I replaced my blower resistor with a 50w aluminium cased power resistor from RS Components. It cost less than £3 inc vat. There was nothing wrong with my blower, other than I wanted to increase the slow speed slightly. I don't recall what R the new resistor was, but it now means that slow speed will keep the screen clear on damp days. Quote Link to comment Share on other sites More sharing options...
blowmeover Posted November 8, 2018 Share Posted November 8, 2018 On 11/28/2015 at 11:28 PM, mickeyw said: I replaced my blower resistor with a 50w aluminium cased power resistor from RS Components. It cost less than £3 inc vat. There was nothing wrong with my blower, other than I wanted to increase the slow speed slightly. I don't recall what R the new resistor was, but it now means that slow speed will keep the screen clear on damp days. Sorry to revive an old thread, but that ally resistor, did you use a heatsink with it? I was going to fit one but the spec says they need a heatsink. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 8, 2018 Share Posted November 8, 2018 I may be being stupid, but that has a heatsink on it already. 1 Quote Link to comment Share on other sites More sharing options...
blowmeover Posted November 8, 2018 Share Posted November 8, 2018 That's just the casing, the spec sheet on RS says they have to be used with a separate heat sink, if not they don't perform to spec, Quote Link to comment Share on other sites More sharing options...
blowmeover Posted November 8, 2018 Share Posted November 8, 2018 Perhaps not all need a heatsink and could be chassis mount but the ones I've been looking at do. https://uk.rs-online.com/mobile/p/panel-mount-fixed-resistors/0157550/?fbclid=IwAR2QT1Lr0I9CQJZNk_6aJrHg4-8bAqTx7pTxArrItIWfNbRVDq9zgqxlEUc Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 8, 2018 Share Posted November 8, 2018 Just google heater resistor. There are tons of generic ones. Pretty much every car in the world has one. Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2018 Share Posted November 8, 2018 I have one of simonB's resistor kits on my 110, its redundant now after fitting one of these kits https://shop.landreiziger.nl/elektronische-ventilator-aansturing.html I'm more than happy to remove it & sell. this kit doesn't need a heatsink the resistor is screwed to the bulkhead Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 9, 2018 Share Posted November 9, 2018 How hot they get depends on how much power is being drawn. In any case this resistor sits in the air intake duct, so has a good flow of cooling air blown across it. It doesn't need anything more. Quote Link to comment Share on other sites More sharing options...
cborrman Posted June 5, 2019 Share Posted June 5, 2019 On 11/24/2015 at 1:25 PM, Red90 said: Have a look here, item 4. Three options depending on which heater you have. http://www.allbrit.de/UNI.cfm?PAGE=760932&SPRACHE=EN None of them cheap!! http://www.johncraddockltd.co.uk/land-rover-parts/utp1904-wiring-assy-he.html http://www.johncraddockltd.co.uk/land-rover-defender/defender-90-and-110/parts/cooling-and-heating/utp1281-wiring-harness-and-resistor-for-heater-90110-r-h-d.html http://www.johncraddockltd.co.uk/land-rover-parts/jgk100170-wiring-assy-he.html Sorry to revive an old thread but I could not find the part on the excellent allbrit.de link, nor anything I would be happy buying off of john craddock (I still have a return for a a wrong product they sent where they have charged me for both and then refunded me £50 less than they should, and I may as well talk to a chocolate labrador than try and explain over an over again that 400 charged for two products, one returned as is, £150 refund for a £200 product does not add up)... anyhoo, have 300tdi 110 which used to have light, sort of fast and full on, but now only has full-on, which is OK on motorway, but a pain elsewhere, will try Simonb, but open to any offers / recommendations (to do with the thread lol) in meantime given age of OP Quote Link to comment Share on other sites More sharing options...
