ande84 Posted December 2, 2015 Share Posted December 2, 2015 Hi Has anyone got any pictures of how a 200tdi exhaust mounts to the chassis please? I have got a na chassis and want to fit a 200 tdi exhaust with my 300tdi engine conversion Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2015 Share Posted December 2, 2015 200tdi exhaust uses the pin & rubber ring type fittings, see page 659 on in http://www.retroanaconda.com/landrover/parts_books/90/7_brakes_fuel_air_exhaust_cool_heat_p581-718.pdf Quote Link to comment Share on other sites More sharing options...
ande84 Posted December 4, 2015 Author Share Posted December 4, 2015 Thanks but was after some pictures of one fitted to a 90 so I can see where the brackets are fitted to the chassis Quote Link to comment Share on other sites More sharing options...
Eightpot Posted December 5, 2015 Share Posted December 5, 2015 A late 300 tdi exhaust is a better fit, using ESR4527 rather than the 200 style sideways mounted rear silencer. For the best fit, cut a section out of the downpipe, 170mm from memory, which then makes the rear flange sit in the normal position for a factory 300tdi. I always cut/reweld the section behind the vertical pipe as its on a slight downward angle and the rear bit then clears the crossmember better...if that makes sense.. You can then use a standard 300 centre box which mounts pretty easy. halfords sell universal exhaust mounts that are useful. I normally weld an exhaust mount on the mid chassis crossmember to take a regular rubber exhaust mount, rear mount is easily modified and then rig one up hanging off the transfer box. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 5, 2015 Share Posted December 5, 2015 I can get some photos, but not until the weather dries up! Quote Link to comment Share on other sites More sharing options...
ande84 Posted December 6, 2015 Author Share Posted December 6, 2015 Thanks That would be great if you could get some pictures Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted December 6, 2015 Share Posted December 6, 2015 probably not best example as mount missing by transfere box. driver side rear back box mount centre mount by aframe missing but by trasferebox. rear tail pipe near side rear rear offside back box mount another of mount by aframe hope that helps. Quote Link to comment Share on other sites More sharing options...
ande84 Posted December 10, 2015 Author Share Posted December 10, 2015 thanks that is great Quote Link to comment Share on other sites More sharing options...
