BIG_TOM Posted December 6, 2015 Share Posted December 6, 2015 Has anyone got a wiring diagram for the auto box here is a picture of the colours im confused about thanks in advance. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted December 7, 2015 Share Posted December 7, 2015 Picture? None attached to original post. Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted December 7, 2015 Author Share Posted December 7, 2015 this is the plug not sure why it didnt upload who knows i dont do computers!!! Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted December 9, 2015 Author Share Posted December 9, 2015 ?? Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted January 1, 2016 Author Share Posted January 1, 2016 Does anyone know????? Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 16, 2018 Author Share Posted April 16, 2018 help....?????? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 16, 2018 Share Posted April 16, 2018 (edited) Its in my thread linky below.....somewhere lol Reverse switch = Brown Light Green with Brown Trace Auto Inhibit = Black Black with light green trace Edited April 16, 2018 by Les Brock 1 Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 20, 2018 Share Posted April 20, 2018 Maybe i could be able to help if you describe better what you are after and where is that plug, how many pins it has etc, so more information cos just saying "autobox wiring" with a small pic is too vague and i dont know where to watch in the diagram Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 24, 2018 Author Share Posted April 24, 2018 On 4/20/2018 at 2:03 PM, sierrafery said: Maybe i could be able to help if you describe better what you are after and where is that plug, how many pins it has etc, so more information cos just saying "autobox wiring" with a small pic is too vague and i dont know where to watch in the diagram Hi Sierrafery, That might help... Well its the main black plug thats from the gearbox wiring loom then from that plug it goes into the rest of the loom just trying to work out what the colours do. i will get the colours tonight. Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 25, 2018 Author Share Posted April 25, 2018 so last night had the car runing, used a multi meter and was getting voltage on nothing down there, or i was getting no "beep" on my multi meter when i was seeing if there was any closed loops. any ideas? Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 25, 2018 Share Posted April 25, 2018 (edited) That connector seems very like being C105 and if it is i'll tell you which wire goes where, see if the wire colours are matching with the pinout, the colour codes are attached as well Edited April 25, 2018 by sierrafery Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 25, 2018 Author Share Posted April 25, 2018 yes that is the connector. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 25, 2018 Share Posted April 25, 2018 (edited) 1- diff-lock switch, 2 - vehicle speed sensor, 3 - reverse lamps circuit, 5 - ground, 8 - transmission oil temp switch, 9 - park/neutral position switch - interlock, 11- Alarm ECU... the others are not used in 300Tdi Edited April 25, 2018 by sierrafery Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 25, 2018 Author Share Posted April 25, 2018 Brilliant so if i earth pin 5, i should get some continuity when i select revers etc. Should of mentioned this is on rover v8 3.9 Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 25, 2018 Share Posted April 25, 2018 Pin 5 should have contiuity to earth the reverse circuit is on pin 3 and it must have 12V on it from fuse F14 with reverse selected Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 25, 2018 Author Share Posted April 25, 2018 (edited) Right below is the list of colours I have. I have put a meter from the gearbox casing to the body and I’m getting continuity i Have put a meter on that single black wire and checked each pin and getting nothing Green and brown Green and yellow black and orange black and yellow Black and red black and blue black and green Red and yellow yellow and black black Edited April 25, 2018 by BIG_TOM Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 26, 2018 Share Posted April 26, 2018 I dont understand what you want.... what's not wrking? Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 26, 2018 Author Share Posted April 26, 2018 The gearbox is sitting in a custom buggy. The c105 connector is coming from the gearbox and that’s it not plugged into anything. I’m trying to connect a set of reverse lights to it aswel as the warning lights for the gearbox. Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 27, 2018 Author Share Posted April 27, 2018 Any other ideas will be greatly received Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 29, 2018 Share Posted April 29, 2018 For what you want C105 is not enough, there must be another roud 5 pin connector(C323) from the gearbox which is the harness for the park/neutral/reverse switch cos the feed goes through this then through C105 to the reverse lights thet custom buggy has a D1 instrument pack fitted or what warning lamps do you want? Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted April 29, 2018 Author Share Posted April 29, 2018 Yes I do have that round connector aswell. No instrument pack all been ripped out. So just a going to use universal warning lights for diff lock switch etc etc and I’m using a set of led reverse lights. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 30, 2018 Share Posted April 30, 2018 I'll check the diagrams and give you clear instructions soon Quote Link to comment Share on other sites More sharing options...
sierrafery Posted May 1, 2018 Share Posted May 1, 2018 (edited) So, for the reverse lights you have to connect a 10A fused live to pin 2(Y wire) of C323 and from pin 3(GN wire) reverse lights one side the other side of lights to earth - diff-lock warning, when the diff is locked the earth is switched to it from C105 pin 1(BU) , the switch must have one pin connected to earth - transmission temp warning, earth is switched from C105 pin 8(BG) the black wire in C105 must be connected to earth Edited May 1, 2018 by sierrafery Quote Link to comment Share on other sites More sharing options...
BIG_TOM Posted May 2, 2018 Author Share Posted May 2, 2018 lovely will have a look when im next up my workshop and report back my findings! Quote Link to comment Share on other sites More sharing options...
