Timdiver99 Posted December 10, 2015 Share Posted December 10, 2015 Hi, I bought my TD 90 in September. On the way home, the fuse (number 5) for the indicators kept blowing. I've replaced the fuse, cleaned up all the connections, and re-earthed all of the indicator lights. Bu the problem is still there; the fuse keeps blowing. The hazard warning switch looks fine, and there is power to all the indicator lights. The final thing might be that where the loom passes through the bulkhead, a wire has worn through. Before I go through the pain of removing and stripping the dashboard, does anyone have any other suggestions?With thanks, Tim. Quote Link to comment Share on other sites More sharing options...
western Posted December 10, 2015 Share Posted December 10, 2015 this might help --- http://forums.lr4x4.com/index.php?showtopic=25376 Quote Link to comment Share on other sites More sharing options...
qwakers Posted December 13, 2015 Share Posted December 13, 2015 run a tempoary wirem see if the problem goes away Quote Link to comment Share on other sites More sharing options...
