Refitting the lt230 bearing carrier
Anderzander
One one of the LT230s I've done the carrier has has two screws that hold it to the main casing. The cover plate then bolts on through the carrier and secures it all. However I seem to recall on the later box it was just held between the two without any additional fixings. I think I might have put a couple of bolts in to guide it into place as you suggest - then remove and fit cover plate and all the bolts.
25nm doesn't sound very much, but it is into an aluminium casing so wouldn't want to strip the threads!
25Nm is quite sufficient, the front wheel bearings nuts for example are only 10Nm. - tighten up to 55Nm, back off the nut 90* and tighten to 10Nm. any less = insufficient preload, any more = excessive preload.
The bugger of it is having to go out and buy a torque wrench that goes that low on the scale - if like me you are Mr Exactimo :blush: (I've really got to get out into the desert more!)
