30mm wheel spacer studs??
Hello all
This may not be the right place for this question but not sure where else to put it.
I almost lost a wheel last week and in doing so I've damaged the captive studs on one of my 30mm wheel spacers.
Anyone any idea where I might be able to get some new ones? They tapped out easily enough. Can't seem to find a good source for them
Thanks in advance
Connor
If they are removable have you compared them against std LR studs? In therory you are just spacing the wheel out by the aluminium bit the studs should be identical to the oem ones? I have no evperience of this but can't see why you would design and make your own if they could use std.
  • Like 1
