garrycol Posted December 19, 2015 Share Posted December 19, 2015 I have my 4.0 engine up side down and was about to put the sump back on and then spotted this hole and bolt holes on the bottom of the block casting. It is on the opposite side to the dip stick. The hole is connected to a "tube" inside the block casting that runs forward to the oli pump area. The bolt holes indicate there should be something there but I have no idea what. My 4.0/4.6 engine build manual does not show anything. So before I put the sump back on - is there anything that is supposed to be bolted to this position. Garry Quote Link to comment Share on other sites More sharing options...
need4speed Posted December 19, 2015 Share Posted December 19, 2015 That's where the oil pick up pipe bolts to on older v8 engines. Don't know if a cover should be there to blank it, but can't see that it would do any harm if you left it as is... Quote Link to comment Share on other sites More sharing options...
garrycol Posted December 20, 2015 Author Share Posted December 20, 2015 Thanks for the advice. Cheers Garry Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 21, 2015 Share Posted December 21, 2015 I think if you chase it through it would actually work with the early-type front cover and pick-up, as it is it's just a spare hole in the block! Quote Link to comment Share on other sites More sharing options...
