Simon B Posted December 21, 2015 Share Posted December 21, 2015 Hello, Whenever I change gear my gearbox makes a weird noise, a bit like a large dog whimpering, it only happens when I press the clutch in or let it out. I had discounted thrust bearing as it isn't there if there is light pressure on the clutch. Input bearing on gearbox has been mentioned, its a split santana box originally from a V8 fitment. Any ideas on how long it will be before it might let go? Quote Link to comment Share on other sites More sharing options...
tacr2man Posted December 21, 2015 Share Posted December 21, 2015 the lt 85 is a bit like the old series box , it will make a lot of noise for a long time and get really bad before it gives up FME Quote Link to comment Share on other sites More sharing options...
jai_landrover Posted December 21, 2015 Share Posted December 21, 2015 Lay shaft bearing are prone in those but they can be god awful before you need to do anything with it Quote Link to comment Share on other sites More sharing options...
