russellc Posted December 24, 2015 Share Posted December 24, 2015 I have a series 3. I've had the flywheel off and have now put it back on (teeth towards the engine). Question: the starter motor teeth do not align with the flywheel teeth. I'm assuming this engages when you turn the key to start the vehicle? I'd prefer to be sure before I struggle aligning the gearbox to clutch. Any tips appreciated. Russell Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 29, 2015 Share Posted December 29, 2015 When you turn the ignition key the cog on the starter is thrown outwards and engages with the teeth of the flywheel. At the same time the starter main body receives power directly from the battery and spins the engine, which then starts (or at least it should do ) Les Quote Link to comment Share on other sites More sharing options...
