Dora Posted December 24, 2015 Share Posted December 24, 2015 Not sure if this is the best place to ask this but here goes..I have four 6 LED lights I want to fix to my roof rack and wire them together on one switch. I was thinking of making up some sort of harness which I can connect each light to in case of failures rather than solder everything together, but would need some sort of T connectors and plugs, preferably waterproof. Does anyone know where I can sorce such things or know another way to do it? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted December 27, 2015 Share Posted December 27, 2015 You could try these. If you hunt around on the bay you might find the same connector broken down so you can fit your own wire to them, however for best results you need a really good crimping tool for the connector inserts. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted December 27, 2015 Share Posted December 27, 2015 You can buy them here: http://www.polevolt.co.uk/acatalog/Small_Superseal_Connectors.html or these http://www.polevolt.co.uk/acatalog/Econoseal_Connectors.html or at various other retaillers, just search for them by name. You'll need the correct crimping tool to make up your harness as well. Quote Link to comment Share on other sites More sharing options...
Dora Posted December 31, 2015 Author Share Posted December 31, 2015 I have seen those sort of connectors but they dont seem to do a T piece so I can daisy chain them. Unless there is a different way of linking them. Quote Link to comment Share on other sites More sharing options...
missingsid Posted January 2, 2016 Share Posted January 2, 2016 Thats why manufacturers make soldered or crimped three way joints in the wires instead it is much cheaper. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted January 2, 2016 Share Posted January 2, 2016 Yep, use a inline butt crimp and heatshrink to create the split. You get butt crimps with the gluey heatsink pre-attached too. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 2, 2016 Share Posted January 2, 2016 I tend to find a soldered joint in that instance to be much slimmer and tidier, with glue-lined heatshrink over of course. Quote Link to comment Share on other sites More sharing options...
Dora Posted January 4, 2016 Author Share Posted January 4, 2016 OK, so the answer is no then.. Not to worry, I've sorted it with bullet connectors and lashings of silicone! Makes it easy as pie to pull apart and replace up under the roof rack. Quote Link to comment Share on other sites More sharing options...
