landroversforever Posted March 14, 2016 Share Posted March 14, 2016 Nice! Is there a reason your main hoop is laid back? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 14, 2016 Author Share Posted March 14, 2016 Nice! Is there a reason your main hoop is laid back? yes, actually there is. The laid back main hoop style is mostly american, and not one I'm particularly fond of.. But in this case it was the only way to have the 'feet' of the hoop far enough forward to clear the tyres whilst the top is far enough back to be behind my head. Any other ways would have required a main hoop with more bends in it, and more bends=weaker. So that's why Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 14, 2016 Share Posted March 14, 2016 That makes perfect sense Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 15, 2016 Author Share Posted March 15, 2016 Moving along rather nicely. Seat+harness in: Rearwinch and fairlead: Steering column and pedals: And finally the dash was painted red and fitted up, won't be done until I start wiring though: And lastly I wanted to show you guys that my painter doesn't just paint in Microns, he paints in Millimeters! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 15, 2016 Share Posted March 15, 2016 Very nice work Soren! Bet he uses a thick brush Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 16, 2016 Author Share Posted March 16, 2016 Engine+gearbox and radiator in. Shocks and front bumpstops mounted: Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 18, 2016 Author Share Posted March 18, 2016 Brakesystem refitted and bled: And gearlinkage painted and fitted: Began on fitting a different steeringwheel and will finish that up tomorrow. Can't stand the look of that Nissan wheel! Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 19, 2016 Author Share Posted March 19, 2016 Today was mostly about wiring, thankfully a very simple task on this thing. Decided to run the wires for the brakelights on the outside of the tube, instead of inside which was my original plan. Just because it will make fixing a potentially bent tube much easier: But I think it turned out okay, even though the wire's are now somewhat visible. Next up got the brakelights lid up! But unfortunately I broke the brake light switch so will have to source a new one, but here's where it sits: Wiring at the "firewall": Fan for the radiator fitted and wired: And finally a picture of the steering wheel fitment, had to space it a bit closer for best possible driving position, so will have to find a piece of some plastic tubing or something to cover up that gaping area: All gauges in and wired: Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 20, 2016 Author Share Posted March 20, 2016 She was outside today! And finally I got her weighed in, which means its quiz-time!! How much do you reckon it ways as it sits on the last picture? Ready to run with all fluids in? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 20, 2016 Share Posted March 20, 2016 Hmmmmm.... About the 1000kg mark without driver? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 20, 2016 Author Share Posted March 20, 2016 Should probably have reminded everybody that this: Was 800kg's Will give you a more fair ground from which to guess Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 20, 2016 Share Posted March 20, 2016 1100kgs Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 20, 2016 Author Share Posted March 20, 2016 Noted Ross Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 20, 2016 Share Posted March 20, 2016 Can I keep guessing and take all the numbers so I win? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 20, 2016 Author Share Posted March 20, 2016 Haha you could, but hardly worth it seeing as there is no prize Quote Link to comment Share on other sites More sharing options...
qwakers Posted March 20, 2016 Share Posted March 20, 2016 1.8ton Quote Link to comment Share on other sites More sharing options...
muddy Posted March 20, 2016 Share Posted March 20, 2016 1380kg Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 20, 2016 Share Posted March 20, 2016 1500kg Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 20, 2016 Share Posted March 20, 2016 Great work! 1400kg wet Quote Link to comment Share on other sites More sharing options...
steve b Posted March 20, 2016 Share Posted March 20, 2016 1330kg ready to go cheers Steveb Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 20, 2016 Author Share Posted March 20, 2016 Great guesses everybody, and I must admit I had overestimated the weight well and truly! My own guess while building was something like 1500-1600kgs, however it was a featherweight of only 1150kgs! And I have less than a 100kgs more to add, so I'm super stoked to say the least! So Ross wins, but then again he did get two chances :P Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 20, 2016 Share Posted March 20, 2016 Impressive! Those logs must've been very heavy Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted March 20, 2016 Share Posted March 20, 2016 looks pretty good! what do you think final cost is? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 20, 2016 Share Posted March 20, 2016 Winner Quote Link to comment Share on other sites More sharing options...
deep Posted March 21, 2016 Share Posted March 21, 2016 Flip, I thought I had read this properly. I completely missed the part where you had used a flexible, wooden chassis! I just got in from work. I guess 1,150Kg. How did I do? Quote Link to comment Share on other sites More sharing options...
