landroversforever Posted December 29, 2015 Share Posted December 29, 2015 My tyre inflator at the workshop has died, so it's time to replace it. What have people got and would you recommend it? I like the type which clips onto the valve and stays on there, not just the push on type. The old one was a cheapy dial type, which is the type I'd go for unless others have better ideas. Do the ones with a straight, rigid, hose become awkward to use? Quote Link to comment Share on other sites More sharing options...
muddy Posted December 29, 2015 Share Posted December 29, 2015 PCL every time, I bought one of these for about £40 and it's spot on, we use them at work, I have mine in my van and use it trialing off roading ect, basicly bombproof and accurate. eBay Will. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 30, 2015 Author Share Posted December 30, 2015 I like the look of that, especially the flexi hose. What's the clarity of the gauge like? It's the reason I've put a couple of that type back when I've been browsing at shows. Quote Link to comment Share on other sites More sharing options...
muddy Posted December 30, 2015 Share Posted December 30, 2015 Its good, to the 2 psi iirc certainly never been a problem for me in the field. I think I even drove over on some long grass with the 90 once and just pulled it out the ground and wiped it off, it gets checked every six months and I don't think its needed calibrating yet. I'd have no qualms about buying another to replace it put it that way. Will. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 30, 2015 Author Share Posted December 30, 2015 That sounds good to me . Thanks for the input Will! Quote Link to comment Share on other sites More sharing options...
dantastic Posted December 30, 2015 Share Posted December 30, 2015 I have the exact same pcl. Brilliant! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 30, 2015 Author Share Posted December 30, 2015 That's sealed it then.... I'll get one on order! Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted December 30, 2015 Share Posted December 30, 2015 A few years ago when I was looking for the same thing, I got one of these. At the time, it was significantly cheaper than the other type, and I was short of cash. It looks like the prices have evened up in the meanwhile but having has the dial type for some time now, I actually prefer it to the other type. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 31, 2015 Author Share Posted December 31, 2015 I like that one a lot! Quote Link to comment Share on other sites More sharing options...
robertspark Posted January 3, 2016 Share Posted January 3, 2016 Have one of the pcl long ones, its great had it about 10 years now. To read the pressure there are two lines offset on the glass, the idea is that the two lines align with your actual pressure reading. So as to offset for any view angle issues given any line marked on the glass and read off a moving dial or needle is relative to the angle it's viewed from. Rob Quote Link to comment Share on other sites More sharing options...
Lewis Posted January 3, 2016 Share Posted January 3, 2016 Yes, always pcl, they are the industry standard, I have one at home and several at work Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 3, 2016 Author Share Posted January 3, 2016 I've ordered one of the dial type PCL ones mentioned above . Thanks everyone! Quote Link to comment Share on other sites More sharing options...
Lewis Posted January 4, 2016 Share Posted January 4, 2016 I've only ever seen the type that Will posted, please let us know how you get on with the dial type Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 4, 2016 Author Share Posted January 4, 2016 Will do Lewis, been shipped out this morning Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 7, 2016 Author Share Posted February 7, 2016 Used it for the first time today. Realllllly nice to use. The air inlet is actually plastic which was surprising so will have to see how that holes up. Overall the unit seems well put together and solid. The dial drops off to zero when inflating, which seems strange but in reality isn't any different to my old one went right up to max when the trigger was held. Quote Link to comment Share on other sites More sharing options...
muddy Posted February 7, 2016 Share Posted February 7, 2016 Nice to get a follow up! How does the end that clips onto the valve feel, they look a little tinny to me but I can't imagine pcl selling something that doesn't work! I just ordered a pull back cast clip to go on the end of the mog airline but nearly went for the 'tin' one as they were cheaper.... Will. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 7, 2016 Author Share Posted February 7, 2016 I've been meaning to do a follow up.... But hadn't used it yet! Clip felt good, but I'll have a closer look at it when I'm next up there and report back. Quote Link to comment Share on other sites More sharing options...
