marktdi Posted December 30, 2015 Share Posted December 30, 2015 Hi the dip stick tube on my 200tdi has come loose . Is it posible to re set to the correct lenth and some how glue to hold it in place or do i need to get a new one if they are still available Thanks for any help Quote Link to comment Share on other sites More sharing options...
western Posted December 30, 2015 Share Posted December 30, 2015 do a search for --- 20tdi dipstick in the defender forum & tech archive, there's lots of info & tech archive includes the LR tech bulletin, they issued a few years ago. Quote Link to comment Share on other sites More sharing options...
steve b Posted December 30, 2015 Share Posted December 30, 2015 They are held with a compression olive , iirc 10mm ID . Without a ref length I'd set by doing an oil change and fill with the correct amount of oil and set using as the max level . The old olive can be removed using a junior hacksaw . cheers Steveb Quote Link to comment Share on other sites More sharing options...
marktdi Posted December 30, 2015 Author Share Posted December 30, 2015 Thanks guys its due a service so thought it be the best time to do it Quote Link to comment Share on other sites More sharing options...
marktdi Posted December 30, 2015 Author Share Posted December 30, 2015 Just found a link western on an old thread that you added for lr series for a new genuine tube .I think that will be my best option Thanks again Quote Link to comment Share on other sites More sharing options...
western Posted December 30, 2015 Share Posted December 30, 2015 you can reuse the existing tube, I removed mine, moved the olive up the tube & increased the tube bottom diameter by pushing on to a pair of closed long nose pliers enough to expand the flared end, shoved the olive & nut back to the measurement as in the tech bulletin & it's been fine since, did this about 10 years ago. Quote Link to comment Share on other sites More sharing options...
