henk Posted January 2, 2016 Share Posted January 2, 2016 Changed the droparm on my 110 to a straight one from a D1 but my turning circle is enormous. I could see only one way to put the droparm on the steering box or do I have to adjust it more by turning the front steering bar more in/out? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 2, 2016 Share Posted January 2, 2016 I wouldn't have thought it would make any difference - although the length could affect its throw ... It won't be to do with the position on the splines - that would just change where you were centred. If the throw is different then just adjusting your lockstops should sort it out. I've had two with disco arms and not noticed any difference. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted January 2, 2016 Share Posted January 2, 2016 its cant be splines as there is a master spline and can only be fitted in 90deg increments. i assume you have changed the steering arm for the longer one to make up shorter TRE? Quote Link to comment Share on other sites More sharing options...
