td5
I did mine from measurements, and they're not quite in the right place, there is tension on the gearbox mounts as the engines perhaps 5-10mm too far forwards. I'm going to have to oval the holes in the chassis to let the gearbox mounts slide forward a little, to remove the tension from them.
I would get some measurements to work from, but as folk said above, get the transmission mounted up and make sure they all work with your truck, rather than just using measurements alone!
 Share
