russellc Posted January 7, 2016 Share Posted January 7, 2016 Could someone please advise if this carb is connected correctly. It seems to me that the choke does nothing at the bottom. Thanks, Russell Quote Link to comment Share on other sites More sharing options...
lo-fi Posted January 7, 2016 Share Posted January 7, 2016 I've got one sat in my workshop that hasn't been messed with, I'll go and take a look later. From memory, the choke is supposed to just knock the throttle open a little. If the throttle plate isn't closing properly, the cam won't hit the peg, and it will do nothing, though, so that's a good place to start checking. Have you just done an overhaul? Quote Link to comment Share on other sites More sharing options...
russellc Posted January 9, 2016 Author Share Posted January 9, 2016 I have issues with fuel. My series 3 won't start without the choke, runs rough and doesn't idle. I just took if off again, opened it up, and it appears clean. But I found this part in the bowl! Do you know where it is supposed to go? Can't find it on the Zenith parts diagram. Quote Link to comment Share on other sites More sharing options...
russellc Posted January 9, 2016 Author Share Posted January 9, 2016 Can't see the part here? Quote Link to comment Share on other sites More sharing options...
Pepé le Pew Posted January 9, 2016 Share Posted January 9, 2016 Nr 39 in the second diagram. Eric Quote Link to comment Share on other sites More sharing options...
Pepé le Pew Posted January 9, 2016 Share Posted January 9, 2016 I have never worked on the Zenith, but according to my manuals it is supposed to sit on the other end of the accelerator pump spindle. Eric Quote Link to comment Share on other sites More sharing options...
russellc Posted January 9, 2016 Author Share Posted January 9, 2016 All sorted. It pays to sleep on it. The part is the Venturi activator. All back in place now and the landy purrs. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
