Whannis Posted January 7, 2016 Share Posted January 7, 2016 Hi guys wondering if you can help? Recently my Electric windows, fan, radio and central locking are all not working I have checked all fuses etc but am no thinking it is possible an Ecu? Anyone else had similar problems? Many thanks Quote Link to comment Share on other sites More sharing options...
teabag Posted January 8, 2016 Share Posted January 8, 2016 Power supply or earths connections, did u check the fusible links as a blown one will remove more than one circuit simultaneously. Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 9, 2016 Share Posted January 9, 2016 Copy what Teabag said, if all your fuses are good then check the MFU (Multi Function Unit alias multi f**ked unit)) located on the rear of the drivers footwell fuse panel. Look for cold joints, these things are soldered robotically by dropping molten solder onto the connection, often they don't properly join. Quote Link to comment Share on other sites More sharing options...
