IanT90 Posted January 8, 2016 Share Posted January 8, 2016 Its been 12 month since my last service and last february did my cylinder head. Recently my engine has been a bit noisey at start up (tappit sounding noise) then after about 10 mins it dissapears. I was planning to firstly check my gaps in valves then do an oil change/service. Hopefully that will sort it out unless the valve caps are worn. Just wanted some advice on the best grade of oil to use based on a 300TDI engine with approx 140K miles on the clock. I have been told you start increasing viscosity of the engine oil as your engine ages. Any recommendations as to the best to use ? As usual any feedback and advice is greatly appreciated. Ian Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted January 8, 2016 Share Posted January 8, 2016 Get the cheapest 10W40 semi synthetic that conforms to spec, and change it every 6 months/6k miles. I go to Wilkos - £15 for 5 litres. If you want more peace of mind then buy an expensive branded oil. I've been doing the above for 5 years and now at 170k miles. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted January 9, 2016 Author Share Posted January 9, 2016 Thanks I will try the 10W40 and change more frequently see how I get on. Quote Link to comment Share on other sites More sharing options...
