Leaking sun roof
unfit
Assuming you have the later type wind up sunroof - remove the glass by unclipping it from the handle, peel down the velvet trim finisher. This will reveal 15 or so torx head screws. Undo all the screws and the sunroof frame can be lifted off the roof. You can then seal it properly between frame and roof with sikaflex etc and reinstall it. I've done both mine like this and are bone dry inside despite current weather.
