ianmayco68 Posted January 11, 2016 Share Posted January 11, 2016 Hi all, I purchased a 70amp alternator from an auto electronics firm not far from me it has connections as per the photo below in the bottom left corner there is a ring terminal marked auxiliary battery positive or split charging relay. I know not a lot about auto electrics but does this mean when i install my split charge kit, instead of running a positive wire from the starter battery through the fuse to the split charge relay to the 2nd fuse then to the leisure battery . I can run the positive from this connection on the alternator to the relay and then onto the leisure battery instead or have I got it all wrong , cheers Ian Quote Link to comment Share on other sites More sharing options...
