Wing duct
the duct on top of wing has loknut insert in the wing metal edge for the outer grille, the actual duct intake for heater has spire nuts on the duct edge of the intake hole & is seperatly screwed to wing with self tapping screws
both sets can be seen in http://www.allbrit.de/UNI.cfm?PAGE=760644&SPRACHE=EN items 19 & 20 = duct to wing & items 18 & 21 = outer grille
TD/200Tdihttp://www.allbrit.de/UNI.cfm?PAGE=758841&SPRACHE=EN
300Tdi & Td5 http://www.allbrit.de/UNI.cfm?PAGE=758475&SPRACHE=EN
turbo intake ducts are fitted with sprie nuts/screws & the grille is fitted to wing metalwith pins on the grille into plastic barrels which push into small holes in the flange for the grille = grille sits flush with wing side skin & no nasy screw heads to spoil the effect as in
