fearofweapons Posted January 28, 2016 Share Posted January 28, 2016 Hello, I am about to start replacing my bulkhead ( well in about a month ) with a galvanized one. While I have a list of seals to buy I was wondering what other bits people have replaced at the same time? For example replace the door hinge bolts with stainless steel. Many thanks for any help. regards, Richard Quote Link to comment Share on other sites More sharing options...
gruntus Posted January 28, 2016 Share Posted January 28, 2016 Hi Richard, Some pointers in an old post of mine. http://forums.lr4x4.com/index.php?showtopic=38064&hl=%2Bgalvanised+%2Bbulkhead Cheers G Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 28, 2016 Share Posted January 28, 2016 Depends what youre starting with, would help to know what the vehicle was. If you haven't already got one, fit a 300TDi clutch pedal assembly with spring assist. Replace the clutch pipes across the bulkhead. Full complement of soundproofing. Quote Link to comment Share on other sites More sharing options...
fearofweapons Posted January 28, 2016 Author Share Posted January 28, 2016 Hello, I am starting from a 1989 110 with 200Tdi and LT77 gear box. The sound proofing idea 'sounds' good. Why replace the clutch pipes? Just because they will be old and it's easier to do while things are in bits?My wings are going to have to come off ( I think ) so are there bits e.g. RTC3744 that I should just go out and buy now knowing that the old ones will be broken / seized when I remove them?What other bits did people end up having to get?Gruntus - I had not seen your post - thanks for that.regards, Richard Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 28, 2016 Share Posted January 28, 2016 Can we turn this into a part number list as well. I am about to do mine (same vintage as yours), so it would be pretty helpful (for me and others i guess) and a useful addition to the tech archive if we can come up with a parts list. Quote Link to comment Share on other sites More sharing options...
Frax Posted January 28, 2016 Share Posted January 28, 2016 Covered my new bulkhead with fatmat, good stuff and easy to apply. Quote Link to comment Share on other sites More sharing options...
Diablo Posted January 28, 2016 Share Posted January 28, 2016 From memory, I had to replace the following, during my rebuild: door bolts (half of them sheared J nuts for the door bolts Selection of the plastic bits that the self tappers screw into (to hold various parts of the dash assembly on) New heater to bulkhead seal (mine was completely rotten) New windscreen seal Vent seals - I tidied mine up and reglued them, although new ones may have been better Bonnet hinge bushes Mine's a 1985 90 Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 28, 2016 Share Posted January 28, 2016 A new chassis. Maybe. Quote Link to comment Share on other sites More sharing options...
Arjan Posted January 28, 2016 Share Posted January 28, 2016 Hmm - interesting read. "fatmat" does not ship to Europe : where did you get it from ? Quote Link to comment Share on other sites More sharing options...
Frax Posted January 28, 2016 Share Posted January 28, 2016 I got it from the bay when I did my rebuild 5 years ago, its good stuff - just cut to size and warm with a hair drier and stick on. I covered the bulkhead + foot wells & seat box and the under side of the foot plates. After 5 years the stuff is still stuck tight even to the underside of the foot plates which is open to the weather. I also fitted it to the inside of the doors behind the door cards, it does help cut down rattles and is also a good insulator. Quote Link to comment Share on other sites More sharing options...
fearofweapons Posted February 1, 2016 Author Share Posted February 1, 2016 Hello Frax, can you recall what type ( thickness ) of FatMat you used and how much?I have 20sq ft of FatMat Xtreme (51mm thick ) for <>£73 on ebay. I'm not sure 20 sq ft would be enough? It sounds like it ought to be but you never know. Regarding a parts list below is what I have got so far. This has not come out as a table - I'll explore how to tidy this up and make it more readable. basically its description, part number, chassis delimiter,blank line, parts manual page number, blank line, estimated quantity. Windscreen Seal ALE1737 Upto KA925389 1 Windscreen seal ALR5058 After KA925389 1 Plate Grommet PRC1333 Upto LA932798 P750 1 Plat Grommet AMR3098 From LA932799 P750 1 Plug Sealing (fits grommet plate) BD155888 Upto LA932798 P751 3 Plug Sealing (fits grommet plate) BD155888 From LA932798 P751 3 Plug (large oval) MTC1650 P750 1 Plug small circular 338015 750 ? Seal ( transfer to bulkhead) MRC8626 754 1 Nut Lokut ( plastic for t'fer to bulkhead fixing) RTC3744 755 9+ ? Nut Lokut ( plastic for wheel arch) RTC3744 783 <>20 ( both sides? ) Shim ( wheel arch fixing ) MRC4037 783 24 ( perside? ) Roof / Windscreen Seal Inner MTC4994 868 1 Roof / Windscreen Seal outer MTC6568 868 1 Roof / Windscreen Seal corner MUC6400 868 2 Quote Link to comment Share on other sites More sharing options...
Frax Posted February 1, 2016 Share Posted February 1, 2016 Hi again - the Fatmat I used was only about 1.3mm thick, I would think that any thicker would be a right pain to fit. I would think 20sq ft would be more than enough to do the bulkhead and you should have some left over. It is easy to cut and bend when warm. http://www.ebay.co.uk/itm/20-sq-ft-FATMAT-XTREME-Car-Sound-Heat-Noise-Proofing-Deadening-Dynamat-Rlr-Avl-/290643812702?hash=item43abb8a15e:m:mAEmNzd_t18IL3Ck0gl6-ow Quote Link to comment Share on other sites More sharing options...
