Yolandi Posted January 30, 2016 Share Posted January 30, 2016 surprise surprise another problem, my brake light come on and off and as of yesterday is permanently on, i noticed some sediment in the cap so thats been cleaned and however its still on, it seems like the float isnt rising and turning the light off, the brakes work fine and theres just under max level of fluid in the tank any ideas? 1 Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2016 Share Posted January 30, 2016 try cleaning the float contacts, you can pop the lid off the top. Quote Link to comment Share on other sites More sharing options...
Yolandi Posted January 30, 2016 Author Share Posted January 30, 2016 I have it looks brand new now, does the float not float if the fluid is contaminated? The fluid hasnt been changed in ages Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2016 Share Posted January 30, 2016 it should float regardless of fluid condition, is there any fluid actually inside the float itself ? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 30, 2016 Share Posted January 30, 2016 Dry off the cap/float assy and give it a good shake, then refit. Mo Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 30, 2016 Share Posted January 30, 2016 Unless you have a very strange car, the brake light switch isn't in the brake line system, it's a mechanical switch operated by the brake foot pedal and accessible from under the driver's side and screwed into a bracket, it could be that it's just sticking and it just needs a squirt of WD40, if it's stuffed, replacements are not expensive or are they hard to replace . Correct me if I'm mistaken but I don't know of any Land Rovers with a hydraulic brake light switch, maybe the latest Range Rovers and Equipes ---- maybe ?? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 31, 2016 Share Posted January 31, 2016 OP is talking about the brake fluid warning lamp on the dash. Quote Link to comment Share on other sites More sharing options...
Yolandi Posted January 31, 2016 Author Share Posted January 31, 2016 ok, stripped the float assembly entirely, cleaned with petrol and made sure it was bone dry, have all the contacts a clean as well but its still not floating, and yes fluid is getting into the float chamber Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 31, 2016 Share Posted January 31, 2016 Then you need a new cap and float switch assembly. Second hand should do. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 31, 2016 Share Posted January 31, 2016 Unless you have a very strange car, the brake light switch isn't in the brake line system, it's a mechanical switch operated by the brake foot pedal and accessible from under the driver's side and screwed into a bracket, it could be that it's just sticking and it just needs a squirt of WD40, if it's stuffed, replacements are not expensive or are they hard to replace . Correct me if I'm mistaken but I don't know of any Land Rovers with a hydraulic brake light switch, maybe the latest Range Rovers and Equipes ---- maybe ?? Add to the list Morris Minors.... Quote Link to comment Share on other sites More sharing options...
