Cornish Rattler
Rattler and son 1971 S11a swb Restoration
Hard to get a datum on very much that's useful on the windscreen hinge, I'm afraid. I'll have another go later.
Unless the camera is tricking me, I'd say that the bulkhead is tilted back at the moment, meaning the joint for the windscreen seal is too wide. Test fit a door maybe? The bulkheads almost always try to lean back, I've found.
She's looking lovely, sure you're very proud!
Share this post
Link to post
On 4/22/2019 at 5:42 PM, Cornish Rattler said:
Here you are
I nearly missed your update !
That does look neater 👍🏻
Share this post
Link to post
Yeah i will have a fresh look at it again once i get my doors.
Share this post
Link to post
Yeah i can't wait to get the engine started :)
Share this post
Link to post
The doors will show you where the alignment needs work, if any. Remember, you can shim the cappings up if the tops don't quite fit.
Share this post
Link to post
Hahaha look at my other thread :o
Share this post
Link to post
Didn't get chance yesterday doing the door seals but i did today still got to finish the passanger side ones tomorrow but here's a few pic's of the reardoor and drivers door seals
Share this post
Link to post
Coming along nicely!
Share this post
Link to post
Yeah I struggled a bit fitting them as although the rivets provided are long enough once everything has been pulled together they just wouldn't grip, also the original holes in the body was to big for the rivets so I ended up drilling fresh holes more or less the same size as the rivets and they worked well then, hope they will seal ok with the doors fitted but I dowt it :(:)
Share this post
Link to post
Not done much since fitting the door seals on Monday but I have made a Disco 2 dog guard to fit the 2a that I had from my Disco days, still need to fit a piece of plywood to yet for hanging my metal detector and stuff to, so once the 2a is back on the road I can start doing more beach metal detecting, I also stripped, cleaned and painted the pedal boxes and accelerator linkages ready for fitting once I've ordered more stuff when I next get paid :)
Share this post
Link to post
On 5/12/2019 at 8:35 PM, Anderzander said:
Well done 👍🏻
Did I imagine it.. or are you putting a headlining in ?
I will be eventually just need to remove the old stuff first
Share this post
Link to post
Rumaging through an old plastic storage box that came with the 2a when we first got the 2a and found a full set of series vent grills and decided to aerosole them in gloss black
Share this post
Link to post
Very Nice !!
...and a lot of hard work..
Keep the momentum !
Share this post
Link to post
3 hours ago, Arjan said:
Very Nice !!
Keep the momentum !
Yeah i was hopeing to get more done but spent most of the day fitting the rear door as i think the van sides i bought last year from billing was from an hard top fitted with a tailgate then who ever had them before me drilled the holes to fit a back door in the wrong place as they was about 1/2 an hole out so i had to keep filing the holes out and fitting the door till i got it right, but i got there in the end.
Share this post
Link to post
