P38 Paul Posted March 6, 2016 Share Posted March 6, 2016 Hello everyone , Is there anything that cause my MAF sensor to fail like a electrical overload or similar , I'm on to the third one in a month now , or am I just being unlucky , All the sensors have been second hand & the second one only did 10 miles before it failed . Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 6, 2016 Share Posted March 6, 2016 How are they failing? Have you checked the voltage the alternator is putting out? Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 6, 2016 Author Share Posted March 6, 2016 Voltage is 13.7 on my multi meter , The failure is that they just don't control the air / fuel mixture & the engine is surging or hunting , Its exactly the same if I unplug it as well . Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 6, 2016 Share Posted March 6, 2016 Do you have access to any sort of oscilloscope that can display the MAF output? It strikes me there are two possibilities; You are buying secondhand the failures other people have had (your purchase defraying the cost of their new item). Your fault is in the wiring, or wiring connectors, between the MAF and the engine ECU. Regards. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 6, 2016 Author Share Posted March 6, 2016 I have no access to a oscilloscope , Where would I find the engine ECU , Is that the one by the battery ? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 6, 2016 Share Posted March 6, 2016 I have no access to a oscilloscope , Where would I find the engine ECU , Is that the one by the battery ? Probably, which engine is it? Although early ones didn't, later diesels had a MAF. I think all petrols had them. If petrol, which size and type? What year is the car? All this may not be relevant, but might as well collect the information. Do you have a copy of the RAVE workshop and electrical manuals? Regards. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 6, 2016 Author Share Posted March 6, 2016 The car is a 1996 4.0 gems , I don't have the RAVE workshop . Cheers David . Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 7, 2016 Share Posted March 7, 2016 I suggest you find and PM Ally V8 on this forum. He has he aptitude, the interest, and the experience of many examples of these engines, through his work in the trade. You need access to RAVE if you are to run one of these vehicles (and plan on maintaining it yourself). There may be a link to a downloadable source in the Technical Archive (I haven't looked), otherwise try Google, or Range Rover sections on other Forums. Good Luck. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 9, 2016 Author Share Posted March 9, 2016 Replaced the MAF sensor today & all is well again , Lets see how long this one lasts LOL . Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 9, 2016 Share Posted March 9, 2016 Do you do anything else when changing the MAF? Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 9, 2016 Author Share Posted March 9, 2016 Do you do anything else when changing the MAF? No , Just connected it up & away it went . Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 10, 2016 Share Posted March 10, 2016 Very strange. Did you buy another second-hand one now? Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 11, 2016 Author Share Posted March 11, 2016 Very strange. Did you buy another second-hand one now? Yes , It was another second hand sensor , What's so strange ? Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 11, 2016 Share Posted March 11, 2016 That you're killing them so quickly, without anything that seems terribly wrong. Have you tried cleaning the ones that failed? Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 12, 2016 Author Share Posted March 12, 2016 That you're killing them so quickly, without anything that seems terribly wrong. Have you tried cleaning the ones that failed? They don't seem that dirty & just to recap " it is an instant failure " with the MAF on my diesel , when that failed , It seemed to play up a bit first & then fail . I'll give a failed one a good clean & give it another try , Cheers , Paul . Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted March 12, 2016 Author Share Posted March 12, 2016 That you're killing them so quickly, without anything that seems terribly wrong. Have you tried cleaning the ones that failed? Hello Ellbekko , Just tried cleaning a failed MAF sensor & refitted it & ------------------------------------------------------ No , Its still not working , Kind regards , Paul . Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 12, 2016 Share Posted March 12, 2016 I'm out of ideas then, I'm afraid... Quote Link to comment Share on other sites More sharing options...
