lapper88 Posted March 17, 2016 Share Posted March 17, 2016 hi i have a slight leak on top of my fuel pump its a thread with 14mm bolt on to it you cant get the nut off fully because it hits the timing case any ideas how to stop this thank you Quote Link to comment Share on other sites More sharing options...
lapper88 Posted March 17, 2016 Author Share Posted March 17, 2016 ps i have a picture with an arrow pointing to the area but dont no how to post it help please Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2016 Share Posted March 17, 2016 to upload a photo have a read of this Photo Linking info can be found in here or use the -- more reply options button bottom right of the reply text box, you can upload direct from your pc max pic size of 2mb Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 17, 2016 Share Posted March 17, 2016 You need to remove the pump and replace an O ring on the bolt.... You cant remove the "bolt" all the way because it holds the Governor inside the pump... Oh and it needs to got back in precisely the same position. Quote Link to comment Share on other sites More sharing options...
