bushwhacker Posted March 17, 2016 Share Posted March 17, 2016 Guys just to clarify which colour drive i require for a 1986 110 1-6 transfer, 300tdi on 265/85/16 tyres I beleive it should be blue? And just to add I may change the transfer to a 1-4 at a later stage what colour drive should I use for it? Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted March 17, 2016 Share Posted March 17, 2016 I am pretty sure it is blue (just took a blue out of my 110 when replacing the transfer box) . It will be the same for either transfer box regardless of ratio. The only time it would change is if you change anything downstream of the transfer box such as tyre sizes or diff ratios. Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2016 Share Posted March 17, 2016 FRC3310 20 tooth blue gear Quote Link to comment Share on other sites More sharing options...
Yolandi Posted March 17, 2016 Share Posted March 17, 2016 Just jumping in here, after changing tyres from standard 7.50 to yokohama 265s my speedo reads 5 or 6 mph faster than actual, what drive gear do i need to change to? Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted March 17, 2016 Share Posted March 17, 2016 My 90 did the same on 265 Goodyears and I changed back to the green, which by all accounts should not read any where near right, but did read bang on with my Garmin. They only take a couple of minutes to change, so give it a try. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted March 17, 2016 Author Share Posted March 17, 2016 Thanks for the info much appreciated. Yolandi 750 /16 should be the same height as 265/75/16. What is your ratio aspect on the yokos that might be were you are getting the 5/6 mph. Although if memory serves me right the last time I had a working speedo it read + 5 mph more than a sat nav. Check it with a sat nav if you can. Quote Link to comment Share on other sites More sharing options...
Yolandi Posted March 17, 2016 Share Posted March 17, 2016 not sure what an aspect ratio is bushwhacker, i have checked it against a satnav and seems to be consistantly 5/6mph faster, actually it devietes more at higher speed, fastest ever was speedo: 86 gps: 77 Quote Link to comment Share on other sites More sharing options...
