mcc1979ian Posted March 22, 2016 Share Posted March 22, 2016 Ok so im at the stage of plumbing up my 4.6 into my 90 but havent a clue a out any of the hoses. Would any of you gents have any advice on which hoses to use or is it a case of build to suit out of various bits? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 22, 2016 Share Posted March 22, 2016 Yeah, the latter, going to be a bitsa Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 22, 2016 Author Share Posted March 22, 2016 Ok. Cheers. Might it be possible to use the stuff from a 50th anniversary? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 22, 2016 Share Posted March 22, 2016 Possibly, but you got a fat wallet? Will depend on what intake/front end you are using on the 4.6... Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 22, 2016 Author Share Posted March 22, 2016 Standard serp front end and plenum. I know a guy could knock me up what i need in silicone but id need hoses first for him to replicate. Maybe see if i can find a very rare breaking 50th Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 23, 2016 Share Posted March 23, 2016 My d110 used disco top hose and a butchered 200tdi bottom hose with a reducer for the rad the rest is 19mm(I think, might be 21?) I/D single ply silicone hose 1 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 23, 2016 Share Posted March 23, 2016 Yup I can help Please put up a few pics and a simple list of what water "Holes / Tubes / Outlets / inlets" you currently have and I'll join the dots for you !Been there done that - several times - you'll prob need a few bits and bobs but I can point you to where to go for them . getthem / ask for !Nige Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 23, 2016 Author Share Posted March 23, 2016 Cheers nige. Will get some photos up at the weekend once im home Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 23, 2016 Share Posted March 23, 2016 I used a few standard V8 Defender hoses cut & joined using an eBay ali fan switch/temp sensor insert as they were the cheapest way of getting a nice beaded hose joiner! From memory the top hose was pretty much bang on anyway, the bottom hose may've been a single bottom hose cut & rotated slightly or it might've been two bottom hoses cut & joined, wasn't much to it anyway. Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted March 23, 2016 Share Posted March 23, 2016 If its a gems 4.6, fit a stat into the inlet manifold, take the heater feed from the inlet manifold side and tee the heater return into the bottom hose. The rest is simple, one pipe from the outlet to the top of the rad, lower hose needs a tee for the header tank as well. Does your rad have twin bleed pipe ports? If so one from the throttle body to rad and then rad to expansion tank. Or one port: tee the throttle body and rad to the expansion tank. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 25, 2016 Author Share Posted March 25, 2016 No sure. Will check when im home tommorrow. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 27, 2016 Author Share Posted March 27, 2016 Ok finally got round the dig jobs and got time to get pics Heater matrix is being replaced so if easier I can relate with straight pipes. Should there be a feed from plenum to brake master? Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 27, 2016 Author Share Posted March 27, 2016 Apologies for the poor lighting, garage ain't too well lighten and its tipping down outside Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted March 27, 2016 Share Posted March 27, 2016 That small bore pipe coming from the lower plenumn will be ideal to hook up to the brake servo. I don't know what temp stat you're going to run but fit it in the front of the inlet manifold like on the earlier v8's and ditch the remote stat. 1 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 27, 2016 Share Posted March 27, 2016 OK To plumb up the water system : Top hose Goes from front of end where stat lives to the top of radiator. Then, hose from Water Pump goes to bottom of radiator, cut this hose and hava feed via a T piece the feed goes up to the header tank. On the RHS of the Inlet manifold near inj 1 / CTS small pipe connect to one of the 2 small take offs top of radiarot. The other small feed goes to header tank. Now, Heater. You should have 1 x 19mm take off at the front area of the inlet - this goes and connect to one of the heater matrix pipes, the other heater pipe need to connect into the pipe which is the bottom hose IE anotgher T piece. I used a late 3.9 RR Tiwn pipe unit that goes across the top of the drover rocker cover - may have one if you wnat - this also has the bleed screw in it which helps get the system air free Hope this helps, its a start !Nige 1 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 27, 2016 Share Posted March 27, 2016 ps Pics re the above type set up on my V8 Porn thread !!!!!!!!!! N 1 Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 27, 2016 Author Share Posted March 27, 2016 Excellent, cheers fellas. I will buy that pipe off you nige if you have it. Will get a look at yer thread too. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted March 27, 2016 Author Share Posted March 27, 2016 Where would this outlet behind the alternator go? Also is the thermostat housed on the top inlet or do I use one of them plastic thermostat housing jobbies? Quote Link to comment Share on other sites More sharing options...
