chris2010 Posted March 24, 2016 Share Posted March 24, 2016 can anyone tell me the following. Td5 90 . fuel sender unit m what range does it work between in ohms . what reading in ohms should I expect to see when the tank is full and when it's empty. Quote Link to comment Share on other sites More sharing options...
chris2010 Posted March 25, 2016 Author Share Posted March 25, 2016 Help, Quote Link to comment Share on other sites More sharing options...
Peaklander Posted March 25, 2016 Share Posted March 25, 2016 I don't have a TD5 and I don't want to sound unhelpful because I'm not!! Are you trying to make it work / test it? Does the fuel gauge work? Can you connect it with the sender outside the tank? If so what happens when you move it manually?? Or maybe there's another reason for asking about it... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 25, 2016 Share Posted March 25, 2016 On my 1991 Defender 90. I measured the sender when out. It shows 330 to 13 ohms when touching the stops and 280 Ohms on the empty line. Quote Link to comment Share on other sites More sharing options...
chris2010 Posted March 25, 2016 Author Share Posted March 25, 2016 My trucks going to be running td5 . Running a td5 gauge .at present My Ali tank doesn't have a sender in to it , I won't be running a td5 sender and pump. Hoping to fit a vdo floatless style sender in to it . So need to see if a vdo gauge is needed also 1 Quote Link to comment Share on other sites More sharing options...
tonydrover Posted March 26, 2016 Share Posted March 26, 2016 VDO floatless senders???? Never heard of these. Just been googling them. What size sender and gauge would I need for my 90? Quote Link to comment Share on other sites More sharing options...
chris2010 Posted March 26, 2016 Author Share Posted March 26, 2016 Not sure on the sender . For my application one that's 180mm tall. And a normal 52mm gauge I believe Measure depth of tank , take half and inch , if not inch , off that measurement that's the length sender you want Quote Link to comment Share on other sites More sharing options...
