Bit of an emergency,Driving south from the attic to the island
The Badger
 Share
Well going via a boat. Howeve, my front transfer box bearing has gone, squeaking badly, if I wobble the prop, it giggles a bit (not loads).
Was thinking of taking the front prop off and locking the transfer box, but the car is full loaded.
What are my options folks.
Help, options, is it better to leave it?
The back of the bearing is should be open to the T'box oil, so unless someone's fitted a sealed bearing it shouldn't squeak even if it's knackered.
Are you sure it's not a uj ? They really do squeak when dry.
I'd unbolt the prop' and check the uj's, you need to fully articulate them, check there's oil in the box and try it.
Managed to get to biltema just before it shut, got me a grease gun and put that in all the props, one of the UJa is a bit wobbly, thought to try that first, it did help a little but not much, still got a nasty squeak. I noticed some oil coming out the front of the front flange bearing, my next tactic is to put more oil in the transfer box, after this coffee though.
Great day to go sailing though, only a cyclone warning on route (Gothemberg to Immingham) don't have any pictures of the route, but it is mostly two types of tree with a lake here and there. Will upload what I have, and some of my northern base.
Ok, just added some on me Flika account - Floda31DRC
Loads of oil in the transfer box, axels and fully greased the props, still squeaks. Not the serpentine belt as it happens when I drive, not when I rev the engine.
Had it up on a life the other day and did check all the wheels so it's not any of them. Hard to check where it's coming from unless I ghost ride the thing, but that just is a bit silly really.
Thought to add since I now have this sorted, I took the front prop off and it was knackered, the UJs were ok really, a little shaky. The bit that was broken, worn was the ball in-between the joints two top joints, is it called a CV joint in the centre yoke? Anyhow, it's off and I am waiting for a new one. Drives ok, just being a bit careful on take off.
 Share
