Autobox oil lines
Aluhok
Hi All,
I converted the V8 110 from LT95 to an ZF Autobox. Now I installed an oil cooler en need to connect it to the autobox.
Will quality hose clamps and hydraulic hose do the job to hold the pressure inside the system?
Michel
Well, I hear not and that it peaks at 300psi. But I have nylon-wrap hose with double clips and it's been fine for years doing winch challenge.
A standard Oxford /intercal cooler is rated sub 150 psi. With good barbs on the hose tails and double clips it should be better than fine with single-wrap hyd hose. (Wire wrap)
This.
There's little pressure through the cooler on a ZF box.
As above , not much pressure , but I double up on the hose clips if it isnt a barbed or ball ended connector, also make sure that the hose you use is rated for the job (eg temp & pressure) , been totally reliable for years .
