ABS
Steveskeggy
 Share
Hi.
I recently ​I purchased my 2001 Freelander 1.8 S.
There is a minor ABS problem with it.
Under light braking, just before the vehicle comes to a stop, the ABS kicks in bouncing the pedal, even though the wheels are not locked up.
It doesn't affect the braking, they still stop the car just fine.
If I use a bit more pedal pressure, it doesn't happen, and it stops just as normal.
There is no warning lights on the dash, and the ABS seems to work fine.
​Do you think this could be a faulty ABS sensor? Or the ABS pump?
​Thanks
Steve
 Share
