supaimpy Posted March 28, 2016 Share Posted March 28, 2016 So was it ever an option or does anyone make a rear door without the window? seen that utilities generally don't have the rear windows, but still have a door window. I want to put a internal bulkhead in place , and need a new door so now would be the ideal time to swap, that and an upgrade on the door security would help . It will also give more options for sign-writing on the rear. Any links to suppliers would be a help Thanks All Quote Link to comment Share on other sites More sharing options...
Guest wunntenn Posted March 28, 2016 Share Posted March 28, 2016 Not sure (and never seen one). But why not just buy a normal door, which will be unglazed, get an alloy sheet cut to fit the aperture, stick it in temporarily and have it all spraypainted, then pop out the alloy panel and give to the signwriter to work on, then pop back in again and fix properly. Get them here: http://www.sp-4x4.com/DEFENDER_REAR_DOORS_s/107.htm Quote Link to comment Share on other sites More sharing options...
mickeyw Posted March 29, 2016 Share Posted March 29, 2016 Don't many commercial users just use vinyl graphics to blank out the glass? This deals with sign writing all in one go too. Otherwise a sheet of ally would do the job with a bit of anti vibration material affixed. Quote Link to comment Share on other sites More sharing options...
neil110 Posted March 29, 2016 Share Posted March 29, 2016 I suppose the "cat flap" and tail gate combination as fitted to a series would also be a consideration. Smaller window to fill in and a different locking set up which may ,or may not, be more secure. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 29, 2016 Share Posted March 29, 2016 You haven't looked at their prices, Neil! Quote Link to comment Share on other sites More sharing options...
supaimpy Posted March 29, 2016 Author Share Posted March 29, 2016 So its either make my own one piece skin or make alloy filler panel with a joggled edge so that the surface is flush. Then add the security from the inside , upgrading the lock and handle will be easier with a new skin , so who makes skins? Maybe able to start with asking if its possible to press one without the window aperture although I doubt the press tool has that facility but no harm in asking Thanks for the replies. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted March 29, 2016 Share Posted March 29, 2016 Why not just cover the whole rear with a large alloy sheet, cut handle aperture and you'll have a smooth surface and a wee bit more resistance to a can opener. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 29, 2016 Share Posted March 29, 2016 They'll still open the lock with a teaspoon. Mo Quote Link to comment Share on other sites More sharing options...
