Series 2 Gearbox oils
tonydrover
  • 2 weeks later...
80/90 GL4 oil is readily available and has the advantage it should be the same viscosity as EP90 when hot but is thinner when cold. This makes gearchanging on a S3 in cold weather much easier. It may also leak better!.
Yes, but you can get EP80/90, which is better as it still has the sulphur which protects the bearings and gear teeth, unlike 80w90.
  • 4 weeks later...
