smudge444 Posted April 2, 2016 Share Posted April 2, 2016 HI I HAVE A LANDROVER 90 (1990)INDICATORS JUST STOPPED WORKING ONE DAY (AS THEY DO)WHEN TURNING IGNITION ON THE INDICATOR RELAY KEPT FLASHING AT DOUBLE SPEED, AS IF THERE WAS A BULB OUT ALTHOUGH NO INDICATORS WERE SWICTHED ON OR FLASHING IT WAS JUST THE RELAYI REPLACED THE FLASHER RELAY BUT THE FAULT REMAINEDI THEN REPLACED THE HAZARD SWICTH AND THIS FIXED THE RELAY PROBLEM BUT THE INDICATORS WOULD NOT WORK (HAZARDS WORKED)I THEN REPLACED THE INDICATOR STALK AND PROBLEM STILL SAME--NO INDICATORS (HAZARDS WORK)NOT SURE WHAT TO DO NEXT (PAINTING IT SEEMS A BIT EXTREME BUT WILL DO IF IT WOULD WORK)WOULD BE MOST GRATEFUL FOR ANY ADVICE CHEERS Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2016 Share Posted April 2, 2016 hi, work your way through this http://forums.lr4x4.com/index.php?showtopic=25376 please don't use capitals for the complete post, it's just like shouting. Quote Link to comment Share on other sites More sharing options...
