what turbo?
Garrett T2 is fitted to the 19J engine.
200 Tdi is fitted with a Garrett T25, Maximum Boost pressure stated in the book is 0.82 bar (12 PSI) measured at the wastegate actuator T piece.
If you start playing around with boost pressure and fueling I think the advice out there is to fit an EGT sensor so you don't over cook your engine. The Tdi's are getting a bit elderly now.
