Pas pump noise when cold
Try the above first, but don't ignore it if that doesn't help. This happened to me a couple of years ago and I ignored it for a while. I think I had noticed a lot of air in the fluid (can't quite remember). When I drove off the drive one day (luckily backwards and in the daylight) I saw a trail of PAS fluid. I stopped and took a look under the bonnet to find the pulley for the PAS pump hanging out of the pump with fluid everywhere. I think it was down to a failed bearing, but was hard to tell as I was looking at a load of broken metal!
I don't know if you would be able to feel roughness in the bearings if you took off the serpentine belt and felt the PAS pump pulley by hand for anything unusual - might be worth a try, I didn't think to look!
"I don't know if you would be able to feel roughness in the bearings if you took off the serpentine belt and felt the PAS pump pulley by hand for anything unusual - might be worth a try, I didn't think to look!"
Yes, you should. The pump should turn easily and smooth;y by hand with just a little resistance from the seal. Any play, roughness or stiffness is indicative of a failed pump.
