johno753 Posted April 11, 2016 Share Posted April 11, 2016 Can anyone suggest where to get a new set of injector's from ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 15, 2016 Share Posted April 15, 2016 Why do you want to replace them? Just check for flow and spray, and if you want, get a service kit and do it yourself... Quote Link to comment Share on other sites More sharing options...
johno753 Posted April 16, 2016 Author Share Posted April 16, 2016 Ok will check these ones. But I do need a full set for the 4.2 vbelt I have waiting to be rebuilt . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 18, 2016 Share Posted April 18, 2016 Is the 4.2 flapper or hotwire? I think it's hotwire which I think means standard clamp-down injectors. Usually I'd say pull them from any rusty hotwire V8, or a D2 or P38 but in the colonies that's not always the cheap option. For new ones, you can use anything high-impedance (Hi-Z) that fits and has roughly the right operating pressure and flow rate. That's the joy of megasquirt - just adjust the REQ_FUEL value to suit the flow rate. They're a fairly standard shape / pressure / connection. Quote Link to comment Share on other sites More sharing options...
johno753 Posted April 19, 2016 Author Share Posted April 19, 2016 Thanks for the replies guess I'll be on the lookout for a tired disco or p38 Quote Link to comment Share on other sites More sharing options...
Quagmire Posted April 20, 2016 Share Posted April 20, 2016 As fridge says, anything will work as long as the flowrate is similar and the injector body dimensions are the same... I have Vauxhall injectors on my 3.5! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 20, 2016 Share Posted April 20, 2016 By "similar" I mean a pretty broad range, you don't want to go lower flow but you could probably get away with almost double the flow if you had to. Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted April 21, 2016 Share Posted April 21, 2016 this page its pretty handy Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted April 21, 2016 Share Posted April 21, 2016 so according to that website you should have Bosch 0-280-150-556 injectors. A quick Ebay search shows theyre fitted to LOADS of vehicles Quote Link to comment Share on other sites More sharing options...
johno753 Posted April 22, 2016 Author Share Posted April 22, 2016 Thanks for the Bosch number there should be able to find that in Canada Quote Link to comment Share on other sites More sharing options...
