Wiring help.
I am rebuilding my 1995 300TDi 90 defender. I am looking for some photos to help with the wiring.
Does any one have a picture of the loom wiper motor connector so I can see which wire goes where on the motor. The plug has been cut off on mine.
Secondly, does anyone have a picture of the connectors on the back of the ignition switch? My switch was loose in a box so no idea what coloured wire goes where.
Thanks for your help.
No pics as my wiring is not standard.
There is a "loom" between the stalk and the motor + feed that directly connect to motor and stalk.
Depending on the version, you'll have 2 speed + intermittent and/or single wipe
The RAVE manuals pinned at the top of the tech archive should have wiring diagrams & pictures of every connector.
If memory serves there was a loooong thread about wipers, possibly intermittent wipe, that made it to the technical archive - that may well have the info needed.
 Share
